Samsung RS21 Fridge Freezer. POWER freeze
(Topic created on: 24-11-2024 09:01 PM)
Johnboy71
Hi,
The power freeze keeps switching on and off constantly by itself. Each time it does so it beeps, same as if I were to press the button myself so is annoying.
The fridge freezer itself works fine, both the fridge and freezer at correct temperature.
Upon doing a panel diagnostic by pressing the 2 buttons on the front panel, it shows there is a error 12, Con Fan Error.
Does anyone know what this relates to? Iy suggests to replace the condenser fan at the back of the fridge, however I can see online that this is usually to fix a warm fridge or freezer.
But I don't have that problem. Does anyone have an idea how to fix this constant beeping due to power freeze?
0 REPLIES 0
