Samsung RF9000 / RF56J9040SR American Fridge Freezer - water dispenser randomly stops working
(Topic created on: 02-12-2020 05:54 PM)
JonRussell
Hi,
I recently bought an RF56J9040SR American Style Fridge Freezer and plumbed in the water feed for the water and ice dispenser, but the water dispenser randomly stops working after a couple of days? The ice dispenser seems to be working ok.
When you press the water button, you can hear the solenoid click and pump start, but I don't get any water coming out.
If I leave it a few days, it sometimes comes back.
I sometimes dismantle the water feed, release the pressure and reconnect it and then sometimes that fixes it too.
Does anyone know if there is a tank in this model ? Does it wait for the tank to chill the contents before it will dispense for example ? Or will it dispense water even if its warm ?
Any ideas ?
Thanks.
Jon.
2 REPLIES 2
PaulyWauly36
Pathfinder
is the filter fitted the wrong way,if you fitted it?
JonRussell
Yes. Its pointing towards the fridge. But maybe I'll take it out temporarily and see if its interfering with the flow.
