Rusty Freezer Door - help!
(Topic created on: 21-08-2017 07:42 PM)
AJ1
Hi,
I'm all new to this but struggling to find answers elsewhere so thought I'd try here...
My RSE8DZAS American Fridge Freezer is approaching ten years old but going strong. Annoyingly, where the water dispenser surround meets they metal door skin, rust has started to form. Internet search for new/secondhand Freezer door has drawn a blank so I have stripped out the dispenser as much as I am able to investigate further. The rust is pretty bad and I can't  see how I would get behind the back plate of the dispenser. I can't seem to be able to remove it from the front of the door and I have no idea if it is possible to separate the inner and outer door skins. If I could do that then the I'd stand a chance of solving the rust issue on the metal door skin from both inside and out, otherwise it's just going to continue.
There is no water leak I can see, observation suggests moisture in air meeting cold from Freezer is causing the issue...
If there's anyone out there that has solved a similar issue I'd certainly appreciate some advice-
replace door
or
remove the inner section of water dispenser to get to both inner and outer rusted surfaces
or
strip door into inner and outer panels and make good the rust
or
sell kidney and buy new fridge that doesn't fit the gap-redesign kitchen around fridge...!
Thanks all
5 REPLIES 5
Hayleyroper81
Hi i was wondering if this was ever sorted because my American fridge freezer has done the same and looks an eye sore
AJ1
Hi,
I never got an answer unfortunately. In the end I removed the plastic surround and treated the rust with special paint from screwfix. I then sanded it down to make it as smooth as possible. Next I bought some black fablon from hobby craft. I traced around the plastic surround and added about 2 cm all around it to make essentially a black border sticker that completely covered all the rust once the grey surround was placed back on.
Not sure if that helps but it looked really good, not bodged at all. Was good for another 3 years until the freezer gave up completely.
Good luck
Biddyjen
This same problem has happened mine. Did you ever get yours sorted?
Hails81
Hi
No i didn't was told to buy a new door!
Fridge monkey
Happened to me too! RB38T 8 series. Rust on 1 year old fridge! On both doors.  Samsung doesn’t recognise it as a fault and doesn’t cover it in their warranty! SHOCKING. Stay Away From Samsung
