chilled water ice dispenser
(Topic created on: 24-08-2017 08:07 PM)
thedoctor2
I am looking to purchase an american fridge freezer with a chilled water/ice dispenser. I will not be able to hook up a water supply for some time so cant use the dispenser which is ok,  but will the fridge freezer run ok if it is disconnected?
1 REPLY 1
TracyR
Yes, the Fridge/Freezer simply needs  to be plugged into the mains. The plumbing is only needed for the water/ice dispenser.
:womanhappy:
Say "hello!" and
Introduce Yourself, or virtually hangout in the Samsung Lounge
