10-11-2021 11:42 AM
I am trying to remove the clear plastic cover drawer front on my Samsung RS50 fridge-freezer. Has anybody come across a how to guide or video showing how to do it? I have tried Googling this and all I get are USA videos which appear slightly different.
Solved! Go to Solution.
10-11-2021 12:03 PM - last edited 10-11-2021 12:07 PM
14-04-2025 09:07 AM
That does not address the question - how to "remove the clear plastic cover drawer front"
Note - clear plastic cover drawer front. Not the drawer itself. The basic question is how to REMOVE the front. Stuff gets trapped at the bottom where the front cover overlaps the drawer base and you can't get at it to clean it.
3 weeks ago
I have exactly the same problem - the bottom of the “humidity fresh” drawer is developing mould behind the drawer front. I’ve just had a very unsatisfactory call with Samsung support who tell me the drawer front does not come off and I should get a specialist cleaner in! If that’s really the case it’s incredibly poor product design.
