Refrigerator RR39M Door handle failing - poor design for normal use
(Topic created on: 18-07-2020 12:03 PM)
Putney
The door handle of our Samsung RR39M refrigerator has failed, from normal use, after a single year (just outside of warranty, of course).
When you open the door, pivoting the handle on the spring-loaded hinges, pushes plastic "pins' which releases the door seal.
These pins are cambered forward to release the door from the plastic housing of the handle. This part of the plastic housing is quite thin, and is clearly not designed to withstand the repeated openings of the refrigerator door.
The plastic hinge covers have now split & failed, making it impossible to open the door.
See the picture of the split where it has failed. We've tried glueing the split, but it is clearly going to fail again.
You can purchase an entire replacement handle from Samsung (not just the hinge ends of course, but pay for the whole handle, which is quite expensive - circa £65 for this simple part).
Why this was not designed as a metal part that could withstand normal use is beyond me. It a simple yet extremely frustrating design fault.
Samsung - do you provide a replacement handle that has been correctly designed to last longer than a few months?
21 REPLIES 21
Madelvic
I pushed Samsung in the topi and was promised a call from I think a product engineer.  Of course that didn’t happen.   They don’t care.
I’ve had another one break since.  Simply a ***** design and even worse customer support
Members_3HLYAmk
Hi Madwlvic, just wondering are you selling any of these ? Darren
Madelvic
Sorry no.  Bought one at a completely rip-off price to fix it
HKP
Same problem. About 2 years ago the top part cracked and a few weeks ago the bottom cracked.  I have the 5 year guarantee but samsung won't  fix it under guarantee..  Samsung say it's misuse!  Using the handle to open the door is 'misuse'! I asked samsung for a new handle to fit myself.  They said no as it would invalidate the warranty which I thought was ironic.
BS1975
Same issues here. Poor design and no help despite being well within warranty! I have complained about this issue. 
Zee7
Same issues for us on our samsung RR39M734OSA
They do nothing and the sample now cost circa £120 from samsung or £86 from eBay whatva joke
HKP
I have a theory on why this is happening.  If the foot level is higher at the door hinge side the door can slam if it is left to swing shut.  If you look at the handle mechanism, as the door closes a bit of plastic pops out behind the part that's cracking and probably weakens it over time.  So I'm going to replace the handle and check that the feet are level so that the door never slams shut.
Zee7
What's the cheapest you have seen the handle I'm getting £86 from Ebay I'm sure there is somehow cheaper if so kindly post a link?
HKP
Try this ebay number  133526577490, it's showing £79.90.
Zee7
Tried that number its invalid
