Heat exchanger and tap
(Topic created on: 02-09-2023 05:12 PM)
Starfish5
My tumble dryer says clean heat exchanger and tap. I have done the heat exchanger but wasn’t sure what tap is?
3 REPLIES 3
Cycle_sloth
It is badly worded. I think it means “tap the 0 button” once you have cleaned the heat exchanger.
Shirthepearl
What is the heat exchanger do I need someone to come do it for me or is it simple enough to do in my own
nitnoy
At the bottom of the dryer (maybe pull out the baseboard so you can see it) is a pop open door. Push the door to release it. There are two handles behind it, one turns up, the other, down. Now you can pull this second cover off to reveal the heat exchanger. It’s lots of fins that get som e damp gunk on them. Use the provided long handled brush to brush up or down to remove the gunk. Be gentle!!put the covers back on in order. The first one with the handles is shaped and will only go in one way. Finally, use the dial for selecting wash modes to select either ‘later’ or ‘okay’’ to delete the message. The select lights on my model are pretty faint so it’s tough to see if one of the words has been positively selected. Hope this helps!
