Fridge water speed
(Topic created on: 15-03-2024 02:27 PM)
James108
Hi ,
I have had an american fridge freezer model RSG5UCRS. The water dispenser has always been slow but I though it was due to my pressure. However I have checked the pressure before the freezer and it is good and getting 25 litres a minute but only get 1 litre a minute from the dispenser.
Is the fridge capped at 1L per minute- what speed do other people get? Trying to figure out if there is a fault in the fridge.
Ive took the filter out as well and speed still the same and checked no kinks in hose
Thanks
2 REPLIES 2
UNKNOWNUSERNAME
Samsung Members Star ★
From experience, Built in water dispensers have always been slow, ive used one in the USA (which was slow) and one in the UK (also slow). So i think its normal.
MPNI2025
TechZilla
It's normal, I suspect it is to prevent splashing or filling your drinking vessel too fast and it overflowing before you react fast enough.
TechZilla - Samsung Members Star
