drain pump 'pulsing' on WW90T534DAW washing machine
(Topic created on: 19-08-2022 03:20 PM)
andy_in_ireland
Troubleshooter
Have the WW90T534DAW - in the middle of the wash cycle when it comes to progressing from washing to first spin (then onto rinse) does the drain pump 'pulsate' whilst its balancing the load for a spin for around 3 mins and then drain pump stops pulsating , then a bit of piece and quiet, then drain pump goes long sound and then machine goes to spin.
I realise its not a fault , and I realise its also normal to balance the load ... but why does the drain pump have to stay on the whole duration of balancing the load back and forth and pulse like this rather than going off or just doing a long continuous noise of the drain pump? - its annoying this 'pulsing' sound and pointless being on and running 'dry' anyway - it cannot do the drain pump any good can it either draining when there is no water or hardly any water to drain?
0 REPLIES 0
