16-10-2020 10:37 PM in
Hi, I have a Samsung washer dryer with the auto dispense function. Up until now it has been working absolutely fine but I’ve noticed that my fabric softener wasn’t loading when it should. I’ve done a drum clean, cleaned all compartments etc and still nothing. This evening I’ve run a rinse and spin to see and have no fabric softener in the machine yet the the dose indicator is showing full when it’s not! There’s also a chugging noise as if it’s trying to dispense but nothing is obviously there (this noise also happens when it was full) I’m at a loss as to what I’m to do?? Has anyone else experienced this?
19-05-2023 10:05 PM in
@polly9 wrote:
yep your right. I should have taken another look before posting. However it should work for the softner side. Thats what Samsung tech support say, although won’t believe it till I try it.
well its not designed for manual dosing of fabric softener either - don't believe it if that's what they are telling you. It hasn't got the required syphon in the soap drawer (that blue thing normally) where you can fill up the fabric compartment and it will go in just at the right time on the last rinse (and not go into the drum on the wash cycle) -
no, that middle compartment is just for manually adding soap detergent or powder ...... at a push at the end of the wash cycle on the very last rinse if you are around you could open up the drawer and manually add some fabric conditioner if needs must , but mainly its there to manually add soap detergent in the form of liquid or powder (after disabling 'Dose per wash' in the menu settings)
01-08-2023 11:34 AM in
Just finished taking the assembly apart, for me it turns out that the fabric softener caused a reaction with the oval seals, causing it to expand and jam up the mechanism. Does anyone know if you can buy replacement seals?
05-08-2023 03:49 PM - last edited 05-08-2023 03:53 PM
05-08-2023 04:25 PM in
I wonder if Holts Instant Gasket would do the job too? - take out old 'out of shape' gasket and squirt some of this instant gasket in its place, wait for it to dry before using , it should be resistant to oils etc.
Or even good quality silicone sealant that goes around baths? - I would get the one that has ani-fungal/anti mould properties.
a month ago
Hello, my name Guy from France. Same problem on my washing machine WW10M86GNOA.
I ordered and am waiting for the O-rings in 35 x 2 mm to test.
Could we take pictures of the end result?
Thanks
a month ago
Thanks
a month ago
a month ago
thanks for the reply and the picture.
I will test this and give my feedback ASAP.
