American fridge freezer door handle loose rsh7unmh1
(Topic created on: 29-08-2020 05:46 PM)
Sue1962
The top of the handle of the freezer door is loose and sticking out it this some I can fix
1 REPLY 1
CarloL
Hotshot
It might be best to have an engineer to look a the fridge @Sue1962. If the fridge-freezer is still in warranty, you can request to have one sent to you from the Home Appliances team either via Live Chat or by calling the number 0333 000 0333. If the fridge is out of warranty, then you will need to get in touch with your closest Samsung Support Centre for this.
