Noise cancelling stops audio on calls
(Topic created on: 20-04-2025 05:22 PM)
Asiff
I have a z flip 6 and ear fun buds. Since I switched from the S10 the noise cancelling on the buds means that the audio on calls is not being heard. If I turn off the notice cancellation the calls are fine. Never had this issue with the S10, I was told it may be because the blue tooth driver is newer on the flip. Any ideas on how to resolve appreciated,
2 REPLIES 2
arianwen27
Samsung Members Star ★
There's a setting for your earbuds that disable noise cancelling during calls so you can hear yourself better. Decent chance you have this on.
Not sure what model you have so can't say where it will be if you even have it. But I have it, so you might JINpwVySwV.png
Asiff
Thanks for the reply. The one I have are ear fun pro 2 not actual buds, they do work if noise cancelling us off, but there is no setting to only turn off during calls, and these are the old ones so no firmware updates
