Go to solution Solved
Battery Learn Passage needs a reset
(Topic created on: 4 weeks ago)
Hello all, as I've been leaving my phone for a while week while learning my usage patterns, I do not think this is the average for my daily use from now on. How can I start over again? Thank you 😊 🙏
johnz237
Samsung Members Star ★
Hi!
Open the dialer and type *#9900#. Scroll down and tap on the Batterystats reset option to erase current battery usage data and restart the learning process.
*Do this beforehand:
Go to settings > Security and privacy, and then turn off Auto Blocker. The code will not work on the dialer otherwise.
5 REPLIES 5
johnz237
Hi!
Thank you so much, 👏
A235GUW
Hello, I'm having the same question on my A23 5G UW, but the code is invalid. Is there a different code I need to use to reset mine?
johnz237
The code will only show as invalid if you don't turn off the auto-blocker first, as the instructions say. If it still says invalid, your device doesn't allow for it- normally if tied to a carrier
A235GUW
My phone is a carrier phone and Auto Blocker is off. What code can I use instead if any?
