Go to solution Solved
S24 Ultra - Camera shift and barn door transition issue while zooming
(Topic created on: 02-02-2024 07:40 PM)
y2kviv
l want to bring to your attention a concerning issue I have encountered with my recently received Galaxy s24 Ultra, which I pre-ordered on samsung.com and received on January 24th.
Upon using the device, I have observed a significant image shift problem when switching between zoom lenses (3x,5x etc) in auto mode. Also I have noticed a barn door  type of transition happening in the camera viewfinder while switching to 3x and 5x lenses. Despite my attempts to replicate the issue in Samsung store devices, I was unable to do so. This leads me to believe that the problem lies within the hardware of my device indicating a potential defect. I'm not sure this is something that could be fixed over a software update either.
I have also come across multiple instances on social media, such as the tweet linked below, where other users are experiencing the same camera issue: [Link to Twitter post: https://twitter.com/smasithick/status/1752733526586491319.]
As a loyal Samsung user for an extended period, I am disappointed that such a quality concern exists in a flagship device. I have high expectations for the performance and reliability of Samsung's products. and this issue falls short of those expectations.
I appreciate your attention to this matter and look forward to a swift resolution.
Issue 1: Barn door transition
Here you can clearly see that the barn door transition happening while switching from 2x zoom to 3x and from 3x to 5x. The transition itself starts from the center and expand to all edges of the viewfinder.
Issue 2: Camera Shift
Here you can clearly see that the image inside viewfinder shifts while switching from from 3x to 5x and vice versa.
AntS
Hi guys,
Just sharing some insight on this one from the latest guidance we have at our side.
"The S24 has a newly applied image fusion and animation effects to blend two images together for smoother lens transitions. Due to that, when changing the zoom ratio from 3x to 5x, afterimages may temporarily appear because of the fusion and animation effects of nearby objects."
And:
"Since the Ultra wide, Wide, and Tele camera lenses are physically located in different positions, there is also a difference in view angle, similar to eye parallax.
Thus, changing zoom ratio leads to camera lens shift which in turn causes a subtle change in view angle. Also, when changing zoom ratio quickly, the preview screen may appear slightly disconnected as it takes time to switch among the Ultra wide, Wide, and Tele camera lenses.
If you move the zoom slowly, the screen transition becomes smoother."
The short version is that (as some folks in the topic correctly guessed), they're a property of the device characteristics rather than a bug/manufacturing defect.
And of course, Samsung always welcomes and appreciates  your feedback with the mind towards improvements going forwards.
58 REPLIES 58
Glenntech
Samsung Members Star ★★
If you go into the support section and phone diagnostics
There you can do a test on the cameras.
If the issue is still apparent, then go into the feedback section and provide feedback there explaining the issue fully
You might have to contact Samsung Customer Support and book the phone in. If you have a participating Samsung Experience Store near you. You can book a slot to get it looked at
Tourbillon De La Vie
Can you post a video of what is happening on your device? Contact Samsung support too
y2kviv
I have added the screen-recording of both the issues to the original post.
aasifstrikes
I have issues while using the rear cameras on pro photo and pro video, the image and video I get is upside down but while using the selfie camera on both the modes seem to be alright. Does anyone else have this issue?
y2kviv
Inside the camera settings, go to Camera Assistant > 'DOF adapter correction' and disable the toggle for it. This should solve the issue of PRO photo/video getting flipped. Hope it helps.
GoanGeek
Hello there.
I have observed the so-called barn door opening that you mentioned.
It appears that Samsung's attempt at smooth transitions may be the cause of the AI effect.
Regarding the image shift, I have seen numerous posts about it.
From what I understand, this issue can be seen on any phone with three or more lenses, as the lenses will shift focus since they are quite far apart.
This will be more noticeable with close objects than with distant ones.
Additionally, someone suggested enabling or disabling the auto lens switch setting (I cannot recall which one) in the camera assistant app to partially resolve the image shifting.
Please keep in mind that the shift is more apparent between 1x, 3x, and 10x for close objects, as it physically transitions between the lenses, unlike between 1x and 2x, which is merely a digital crop.
I hope I have addressed some of your concerns.
Nonetheless, this is an issue that Samsung should be made aware of.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
aasifstrikes
Thanks, it worked🙌
Dammy3
I have exactly the same problem as @y2kviv with my S24 Ultra. Did Samsung solve that one for you, or should we wait for some kind of software update?
y2kviv
I have tried most of the solutions suggested in the Samsung community with no luck. So I'll be taking my device to Samsung experience store to get this issue sorted.
