S24 ultra battery drain
(Topic created on: 13-04-2024 05:28 PM)
S24ultra
  i am having problem with the battery life of my s24 ultra. It is continuously decreasing estimated battery timing. It started from a full battery would last around 2 days and is continuously decreasing. While on idle it drops more or less at around 1%/hour and while using it drop continuously.
I have attached ss to show my exact usage. Also i have set setting to cut of charging at 80%.
I am not sure if it is good enough or i am just overthinking.
32 REPLIES 32
ShazB07
Big Cheese
I checked this and put my battery to basic, using modes and routine to alarm at 85% It's working for me cos I'm not a heavy user. Hope this helps. 😊1713040547747.jpg
S24ultra
Can you please tell how much abttery backup are you getting with these settings?
GoanGeek
Samsung Members Star ★★
You seem to have poor network . From your screen it looks like you are running on edge which is quiet slow for a phone like yours which should be on 4g or 5g.
You might wanna consider upgrading your sim to a 5g network.
Estimated battery time varies everyday depending on how you use your phone.
Apps using background location and data will use up more battery which will increase with poor signal.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
S24ultra
 yes on that particular day i was travelling and at the connection strength was not always 4g.
But in the ss i just shared, phone is connected to wifi since last charge and hasn't been on mobile data for a minute but discharge rate is almost same i.e 1%/hour and that over night while i was asleep.
Also, i keep my location settings off, only turn them on when i need to navigate or need to know my exact location. As far as apps are concerned, i have put half of them in sleep and deep sleep category.
Reylob
Hi @S24ultra
How long have you been using the phone for?
Were you not experienced this issues before? When did you notice this?
It took my S24 Ultra around 6 weeks to get stable battery performance
Technology enthusiast, but not related to any technological company.
ShazB07
Big Cheese
This is my current battery status. There's not a lot of difference between us. (I'm no expert), but I do have my battery protection on basic, and yours is maximum. 1713076117198.jpg
S24ultra
I have been using it since last 2 weeks. Inserted sim a week back. For first week i just kept it as a side phone.
I hope mine would also stabilize in a month time.
S24ultra
Yes it is more or less same
Reylob
If you have been using the phone for two weeks then your phone is in the learning phase still.
The phone has a "learning" period and after that it stabilises the battery performance.
I could barely get a day from the one charge and now it says it can do over 4 days, but I charge it every 3 days or so, depending on use.
