Battery widget problem.
(Topic created on: 18-08-2025 06:33 AM)
woodlouse
Helping Hand
Good morning everyone!
My battery widget on both my homescreen and lockscreen on my s24 ultra is playing up .
It's the one that shows the phone and watch battery levels side-by-side.
Recently, the watch battery level keeps on greying out, and then comes back again.
Anyone know how I can fix this please?
5 REPLIES 5
Tourbillon De La Vie
Samsung Members Star ★★
Did you try removing and then replacing it. Is power save or some other battery optimization on for the app. Bluetooth always on
woodlouse
Helping Hand
Yes, I did that. No change.
It's been working perfectly for a long time, but has been doing this for the past few days.
I've not changed anything, settings-wise.
Bindex
Hello, I've encountered this random bug before; I just did a clear cache partition and it fixed it for me straight away. I'll post the steps down below on how to perform a clear cache partition:
To clear your phone's cache partition:
1. Connect your phone to a PC.
2. Turn off your phone (it won't enter Recovery Mode if it's on).
3. Press and hold the Volume Up and Bixby/Power keys simultaneously.
4. Once the Android Recovery screen appears, release both buttons.
5. Use the Volume Down button to highlight "Wipe cache partition."
6. Press the Power button to select it.
7. Use Volume Down to highlight "Yes," then press Power to confirm.
8. After the cache is cleared, press the Power button again to reboot your device.
Tech Enthusiast | Need tech help? Just drop me a message!
woodlouse
Helping Hand
Thanks, I'll try that 👍
Bindex
Ah okay, well just let me know if it fixed your issue, like it did with mine.
