S24 Ultra Battery Drain
(Topic created on: 23-02-2024 10:39 AM)
AK97
Hello guys, I got my S24 Ultra around three days ago and the battery seems to be draining a lot, I'm getting less than 6 hours screen on time, I've read here that transferring data through smartswitch might be the reason but I'm not sure if that's the case, I did use smartswitch to transfer the data but is it really the reason behind this drain?
Kindly help me as I'm so inconvenienced about this.
PS. In the device care it shows "Learning Usage Patterns" and I can't see the predicted hours remaining.
Galaxy S24 Ultra #battery
4 REPLIES 4
Piper123
Samsung Members Star ★
Hi there
In the first 14 days, your device learns your usage pattern and will then adjust your battery's performance accordingly.
That is why, under battery in your image above, it states Learning Usage Pattern.
I am not employed by Samsung nor do I receive any remuneration as a Samsung Members Star.
My device is an S25 Ultra.
Piper123
I would also recommend, as you brought data over via Smart Switch that you perform a Wipe Partition Cache on your device (this removes pesky temporary cached files and doesn't delete your data).
It is recommended to do this after every major OS update and periodically after monthly security patch updates (I do mine 3 monthly).
Piper123
1. Turn off the device.
2. Connect To Computer. Press and hold the Volume Up key and then press and hold the Power key
3. When the Android logo displays, release both keys.
4. Wait until the Android system recovery menu options appear.
5. Press the Volume down key several times to highlight wipe cache partition.
6. Press Power key to select.
7. Press the Volume down key to highlight yes, them and press the Power key to select.
8. When the wipe cache partition is complete, Reboot system now is highlighted.
9. Press the Power key to restart the device.
You can also Repair apps via the Recovery Menu.
MuhammadAHQureshi
This worked for me.
