07-02-2024 07:25 PM
27-02-2024 02:27 PM
27-02-2024 02:28 PM
27-02-2024 03:25 PM
I work from home, so I am on Wifi most of the time, I have 5G activated, using 2 SIMs. I've put all the apps that appear to run in background in sleep/deep sleep (whatsapp, chrome and what appared in the battery usage), set light performance mode, turned off AoD, disabled NFC, WIFI and UWB scanning, used Dark mode and still I have max 5 hours SoT!
28-02-2024 11:43 AM
28-02-2024 11:55 AM
29-02-2024 11:17 AM
01-03-2024 12:07 AM
Hello again! Little update.
I reset to factory settings a week ago and exited learning pattern process yesterday.
After a first charge that gave me almost 8 hours of SoT, the second one lasted around 5.5 (no power saving, maximum resolution, apps running in the background and normal usage).
I actually like power saving mode since it makes no difference to me so I turned it back on, I turned off ram plus, set to light performance mode and put almost all the apps in deep sleep.
I noticed that the battery keeps draining suspiciously, especially using some apps like Instagram, Twitter and Aliexpress. Even browsing with Chrome and opening multiple tabs gave strange results (phone heating and battery draining).
My last charge lasted almost 48 hours.
Should I wait for the phone to exit the initial 1/2 weeks phase that we were talking about before, even if I factory reset it?
Or should I start thinking my phone is faulty and ask for a replacement?
All this trouble for a new ultra phone is kinda crazy to me.
01-03-2024 03:36 AM
2 days old s24 ultra . Used smartswitch. 99% battery usage / 9h 18m. Is it good or I. Must do smthg?
01-03-2024 06:00 AM
Hey,
I also bought s24 Ultra recently and I also used smart smart switch to set it up.
On the first day, I am also having similar experience. 3-4 hours SoT. Does it really get better?
01-03-2024 08:46 AM
