S24 Ultra Battery Drain
(Topic created on: 07-02-2024 07:25 PM)
Billymayn
Voyager
Hi s24 ultra owners,
Got my phone couple of days ago and battery life has been terrible. Getting only 3-4 hrs screen on time with moderate usage.
I used smart switch while setting up the phone
Anyone else having same issues or I have got a faulty phone, with a new phone I am expecting at least 7hrs screen on time.
Thanks
255 REPLIES 255
BandOfBrothers
The battery will still be in the learning phase @Billymayn
Also as it's a new battery it won't reach optimum output until its been charged and discharged a few times.
Take a look in your Device Care Section under Battery to see what's using your battery also.
If I can be of any further help then please don't hesitate to ask.  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Piper123
Samsung Members Star ★
Hey there
Your device will be in the battery learning stage that takes up to 2 weeks. It will learn how you use your device and optimise the battery.
For the type of usage you mention, at the end of the battery learning I would expect between 1 and 1.5 days overall.
As you used SmartSwitch, it might also be advisable to perform a Wipe Partition Cache as well to clear out any pesky temporary files.
S24 Ultra
Billymayn
Voyager
Bro I have used new phones in the past and their battery life were insane. I owned s23 ultra and s21 ultra. Both were too good when new. 😕
BandOfBrothers
@Billymayn I too have e owned quite a few phone's in my time 😉,  and find that phone's perform differently especially android phones as we all set up our phone's differently and use them differently and use different apps etc.
Battery stats is a subjective topic.
The phone is new and will need to be used to allow optimisation as previously suggested.
Billymayn
Voyager
Ok I will give it a couple of more days before I do a factory reset. It is a pain to set up new phone
Billymayn
Voyager
Yes it is telling me learning usage pattern. My only concern is that on previously owned phones battery life was great from day 1.
Piper123
I had the S23 Ultra and S21 Ultra and both went through similar cycles.
I use my S24 Ultra for about 9 hours a day streaming, a couple of hours on top of this for SOT and about 30 minutes of calls and easily get 24 hours battery.
I also tried more normal use. Couple of hours SOT and a small amount of streaming plus 30 minutes of calls and got 2.5 days battery.
S24 Ultra
Billymayn
Voyager
Currently I am at 23%. Charged my phone to 100% 6:45 am. Current time 19:40pm
Day consist of 2hr 45 mins of train travel, all day on 4g/5g.. What putting me off is by the time I get to my office in the morning my battery is 82% with 40/ 50 mins of screen on time.
Currently SoT 3hrs 20 mins
I am gonna leave it until it dies off to see how much SOT i get.
UNKNOWNUSERNAME
Your device is still getting used to you as a person, say you borrowed my phone for maybe 2 weeks, you would notice a different in battery. its because its in its learning phase, give it atleast another 2-3 days so it gets used to you. dont worry😊
MPNI2025
