S24 plus battery drain began 2 days ago
(Topic created on: 07-03-2024 08:31 PM)
I have this problem too (3)
KyleG56
Hi Folks,
My battery on my new s24 plus has been amazing since I got it 1.5 months ago. 2 days ago phone started to get hot and battery draining fast even on battery save mode.
I just cleared cache by following instructions but my phone was 99% charged this morning on battery mode and with 2 hours of screen time 6 hours total day time phone is now on 31% and gets got from regular use.
Why is this happening now? Someone mentioned others have got it after a system update? I closed all apps and everything and still draining. My battery use history is showing twice as high last 2 days despite same screen time.
Example- today 2 hours screen time 70% battery used. Before my issues I'd use 4 hours of screen time a day and use 40-50% battery.
Please help!
18 REPLIES 18
Yuri_the_fury
Have you solved the problem? I have the same issue
kyu173
yes today I checked for new updates on the s21 ultra and received an update. after this update, I installed Company Portal app again.  currently it works. no heat, no battery drain 25% per hour.
after reinstallation I needed to disable battery optimisation in the settings of company portal app.
OneLoveMic
Yes, this worked for me. I just turn on the work apps when I need to use it and turn off again. It certainly is needing a fix!
NiteshSukalikar_49
Same issue after march update..battery was like boom 1-2% down
NiteshSukalikar_49
Which application? Can you please explain it more?
kyu173
samsung February update does not like Microsoft company portal app
AllesMunn
It is quite ridiculous that these things are not being checked by Samsung, every 2nd person I know uses a work profile on their phone given the increase in remote work/working from home. Had a chat with Samsung today and they did confirm a fix is in the works at least
OneLoveMic
I'm so glad to hear they are working on fixing this! I use it everyday... I had work apps on for an hour and it drained 35% battery.
gazwales
Hopefully there is a fix as oneplus gets 9+ hours ost I'd expect 7 minimum from samsung
