Charging and cleaning dist from charging port
(Topic created on: 22-07-2024 12:56 PM)
ItzZia
Pathfinder
Hi all!
Sometimes we all get dust inside our charging port and when we plug in our charger into the charging port, sometimes the charger can pop out easily.
I always thought using a pin or anything that is useful can take out dust from this charging port, Is that recommended or do you guys prefer other methods? If so what is it.
10 REPLIES 10
MorningBlunt
Troubleshooter
Compressed air will do de ting
MB
ItzZia
Pathfinder
But what if I don't have a compressed air, then what shall I do
MorningBlunt
Troubleshooter
Either get on Amazon and buy some or get good at blowing 'really' hard.
MB
ItzZia
Pathfinder
Cheers mate! I'll give that a try.
BandOfBrothers
@ItzZia sometimes using compressed air can drive dust further into the phone unfortunately.
Prevention is better than cure so in my case from eBay I purchase usb_c port silicone bungs that push into the charing port to stop any debris getting into it.
If i can be of any further help please don't hesitate to ask  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Robin999
Legend
Hi, if you must use a pin, try to find a hard plastic one. I wouldn't recommend using any metal objects in there.
ItzZia
Pathfinder
Thank you
TRY2HELP
Helping Hand
I use a vacuum on my phone and all my other device, at least once a month, I hoover the charging port , speaking, microphone, and the hinge of my fold 5.
ItzZia
Pathfinder
Does it do a good job
