Wifi problem after updated to UI 6.1 on S23 Plus
(Topic created on: 29-03-2024 11:41 AM)
Loft_Lo
My S23 Plus connects to my Asus RT-AXE7800 router, which is a Wifi 6E router. Before updating to UI 6.1, there was no Wifi problem. After I have updated my S23 Plus from UI 6.0 to 6.1. I have found that when it is connected to the router in  Wifi 6E mode, it says no internet or the connection fails. It only connects to the router in Wifi 6 mode stably. It seems that this is a bug of the update. Is there anyone who has the same problem out there?
30 REPLIES 30
Tourbillon De La Vie
Samsung Members Star ★★
Did you try to restart the phone and wipe phone cache? Also forget and re-add network connection
Loft_Lo
I restarted several times as well as forgetting and re-adding the network connection, but no help.
Taylorob
Same issue. Wife has s23fe with 6.1 update and works fine. Mine also worked fine pre 6.1 update
Artekkers
Same issue here, wifi 6e connects and then disconnects. Reconnects to wifi 6 and works fine. Is wifi 6e working for anyone on this phone?
Loft_Lo
What is the model of your 6E router? I'm wondering if this bug is causing the issue among all 6E routers or only Asus 6E routers.
Members_KOvxKec
I've got the same problem. All of a sudden, my S23+ is taking an age to load all Apps when connected to my Sky Broadband. Disable wifi and the App will open instantly on mobile data. Cleared all the caches and tried multiple restarts, etc. All other devices at home are running fine on wifi, but not my phone. There is clearly a bug in there and Samsung need to get it sorted.
Loft_Lo
Try switching your router from Wifi 6E to Wifi 6, this solves the issue temporarily.
Members_V49jdv5
Hello,
Same problem but with a S22+ and an Asus RT-AX86U router in Wi-Fi 6 (no Wi-Fi 6E) and configured in AP mode.
Loft_Lo
Do you have a solution or any workaround?
Any problem when connected to your main router?
