28-09-2023 04:26 PM
Is it normal that I still have the Wifi6 problem with my samsung 23ultra ?
I did a factory reset and all. The device is updated.
Did someone found a solution ?
Solved! Go to Solution.
22-11-2023 07:49 PM
Receive android 14 update today November 22nd, 2023 in Canada. Seems to have fix the wifi6 problem.
Thanks to everyone for you reply
28-09-2023 04:50 PM
28-09-2023 05:30 PM
28-09-2023 05:41 PM
the Wifi 6 is not working properly. I tried to factory reset the phone, but it's still not working. All other device connected are working fine. It's a known issue, a lot of user said it was fix with the April update, unfortunately it wasn't for me. My phone is working fine on other network not using wifi 6 technologies, or on my phone data.
28-09-2023 05:43 PM
28-09-2023 05:47 PM
Here is the message I get when I am trying to connect to my wifi. Yet again my wifi is working great, but apps or website are not loading properly only on my phone.
28-09-2023 05:50 PM - last edited 28-09-2023 05:50 PM
Tank you, how can I access this beta please?
28-09-2023 06:06 PM
28-09-2023 06:28 PM
Unfortunately, the beta is not available in Canada for what I can understand. But I found out that the one UI 6.0 update should come out in October (hopefully). I will wait to see if it comes out. If not, I guess I will have no choice except sending my phone to Samsung for repair. Thank you very much for that info.
28-09-2023 06:35 PM
