Go to solution Solved
Samsung S23 ultra, wifi6 problem
(Topic created on: 28-09-2023 04:26 PM)
camcam3
Is it normal that I still have the Wifi6 problem with my samsung 23ultra ?
I did a factory reset and all. The device is updated.
Did someone found a solution ?
Go to solution
17 REPLIES 17
Marselaar
Pioneer
What router do you use? Wifi 6E (ax)?
camcam3
adtran 854-v6
not sure about the WIFI 6E 😕
I still have the same problem. Can't wait the have the android 14 update to see if the problem will be fix
LonnieOne
My caller id does not work when wifi 6 or the high speed access Packet running, either. Plagued Samsung with error logs ,videos, photos etc and still the Samsung experts cannot help me.
Marselaar
Pioneer
Thats a router with wifi ax on board. That is probably causing the trouble. Until Samsung fix this (if it ever will), you can workaround it by in the router settings disable wifi6 ax protocol.
camcam3
ok I will try that. thank you
camcam3
Receive android 14 update today November 22nd, 2023 in Canada. Seems to have fix the wifi6 problem.
Thanks to everyone for you reply
aqueleMetal
I'm waiting for this update in Brazil
camcam3
Hope you will get it soon !
