01-10-2024 12:14 AM
01-10-2024 05:42 AM
Hi @Sarraf 👋
I havent experienced any negative impact on my usage times but as battery stats is a subjective topic as we all set up our phone's differently, and use different apps, and use them differently then usage times can vary.
Do check if you haven't already in your Device Care Section under Battery to see what apps are using your battery.
There is the optimisation tool to tun in that section too.
A good generic troubleshooting step is >
Clear Cache Files from the phone's System Partition Section > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop or use a Tv's USB Port to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too { Possibly excluding the s²⁴ Series of phone's }
There js also the option to put vampire apps i.e Facebook etc into Sleep or Deepsleep Section.
Double check resource functions such as location and sync settings.
If i can be of any further help please don't hesitate to ask 😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
01-10-2024 07:55 AM - last edited 01-10-2024 07:56 AM
01-10-2024 11:38 PM
