Bluetooth connection problem S23
(Topic created on: 24-11-2024 05:30 PM)
Members_dlEdhCI
Hi !
I have a very strange problem. I'm using earbuds (JBL Tune 230nc tws ) I don't have any problem connecting my Phone to them or listening to music or a video. But as soon as I pause my music/video the earbuds begin a cycle where they disconnect and then reconnect to the phone endlessly as long as I don't play something. Each time they make their connection sound and I receive a notification telling me they are connected. Can someone help me ?
Thank you in advance !
3 REPLIES 3
ChrisB_
Hi there, @Members_dlEdhCI and welcome to the Samsung Community forum. 😃
We have a handy guide on our website that may assist you with the Bluetooth issue you're having with your S23 and earbuds. It'd be worth going through the Troubleshooting section to see if this offers you a solution: https://www.samsung.com/uk/support/mobile-devices/how-do-i-connect-a-bluetooth-headset-to-my-samsung...
In addition, I'd also suggest resetting the network settings on your phone. This will reset Wi-Fi networks and passwords, cellular and Bluetooth settings, and any VPN and APN settings that you've used before.
> From the Home screen, swipe up or down to access your apps.
> Select "Settings".
> Select "General management".
> Select "Reset".
> Select "Reset network settings".
> Select "Reset settings".
> Enter your screen lock PIN, Pattern, or Password and select "Next".
> Select "Reset".
Should this not rectify the problem, I would recommend sending us an Error report, as doing so will allow our software engineers to receive data logs relating to the issue you are experiencing. This data is anonymised and only held for the duration of the investigation of the report.
You can find step-by-step instructions on how to send an Error report via this helpful guide: https://eu.community.samsung.com/t5/mobile-apps-services/samsung-members-app-how-to-send-an-error-re...
An expert from the Samsung Members team will respond to your report as quickly as possible. You will find their response in the section titled "Check feedback you've sent" in the Samsung Members app.
Members_dlEdhCI
I will try it thank you !
ChrisB_
No problem. Please keep us updated on how you get on.
