S22 Ultra Exynos unexpected battery drain after March 2024 update
(Topic created on: 23-03-2024 06:42 PM)
Antoan
Hi.
I have S22 Ultra EU Exynos version and I have massive battery drain after 2024 update. It is so large that phone is discharging even on old Samsung 5V wireless pad.
Things I tried:
- clearing cache from boot menu
- google play system update (that is Feb 24 currently)
- updating all apps
- trying different launcher that one UI
- disabling apps
There is nothing unusual to be seen in battery settings - like app that is draining too much, not even in Accu Battery app or thru console. Is there anything else to be done except for factory reset?
Thanks.
14 REPLIES 14
Tourbillon De La Vie
Samsung Members Star ★
Did you restart the phone and clear phone cache
BandOfBrothers
Samsung Members Star ★★
Hi @Antoan
I appreciate you have tried some troubleshooting steps including " clearing cache from boot menu "
Are you also able to try > Safe Mode  > https://www.samsung.com/uk/support/mobile-devices/how-to-start-my-galaxy-device-in-safe-mode/ turns off downloaded apps and themes etc which may highlight an app or theme that's causing conflict.
As a last resort back up and factory reset.
If I can be of any further help then please don't hesitate to ask.  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Awood35208
Pathfinder
I had this issue after Feb patch on s23. I factory reset and my battery stopped draining fast
Lee5G88
Pioneer
I'm feeling like I have a very similar issue on S22 Exynos 2200.
Nothing particularly stands out, and I've tried to recondition the battery by clearing cache and then 0 - 100% charge.
Not a lot seems to have changed, and I'd much prefer Not to factory reset...
Sent from my SM-G973F
Antoan
Thank you guys. It was data transfer tool app that was acting weird. After disabling it, the battery drain went to normal.
pagagagamate
Pathfinder
How do you get to this menu?
capi_noha
Same here on S22. Wipe cache won't help.
Andreas___
Same here. Max power saving does not help.
Harish4
Same here... maximum life of the battery is 7 to 8 hrs... while not using much  and 5 hr if u r using it moderate
