S22 after few days lags on menu and slow WiFi speed
(Topic created on: 30-04-2022 03:27 PM)
Kamper
I bought S22. Turn on. Make pre config, make update, make factory reset afer update. I did preconfig, install apps. I use my phone since 3 days since last restart. Today i saw that menu has "lags", i did internet speedtest.net - was about 40/40. I didnt do anything special since last restart. SMS/tel call, Internet.
I did restart (power off/on) and have no lags and WiFi around 500/40 (my internet speed is 1000/40).
Samsung what is this? How is it posible that after few days of normal usage something like this is happening?! The situation should not happen with equipment for such money i think. And what do you think?
I use my phone for calls, YT, Google.
14 REPLIES 14
Phil6
It's quite widely reported on support forums that the S22 series is having issues with data speeds on WiFi and cellular networks. Samsung isn't really responding at the moment.
LeoXXL
Pioneer
Before looking into your phone, try checking your router speed on different devices, like your computer. If you are checking your speed with WiFi, the average speed you can get is around 500mb/s and depending how far you are from the router, as you mentioned your Internet speed max is 1000/40. Try as well to reboot your router as sometimes it is the source of the problem.
Kamper
Yes, I checked on other devices and it was all normal on the another phone and on the laptop (about 600/40 on the WiFi and the same place - before someone ask 😁). On the S22, everything returns to normal after the restart of the phone, on the same place of the room (before some one ask). And I checked that there is no other network on my channel, and I didn't use microwave and it doesn't matter because I tested on 5GHz.
This is my laptop score:
And this is S22 for about 15h since last restart :smiling-face: I set the same server.
And this is after restart:
-Robot-
Samsung Members Star ★★
I have not had an issue with connectivity or speed.
I would stop reading support forums, as it making you look for problems
Kamper
Again after few hours problem:
 This is not only the WiFi problem. All phone looks like it lost performance - even moving up/down on Settings list menu is lagging. When i see this menu i do the WiFi test. So this is some overall performance issue.
Cleaning network settings, cache, airplane, router restart doesn't help, just restart of the s22 fix performance UI issue and wifi speed.
Phil6
Full 4G+ signal speed test, S10+ was really quick in identical circumstances. It shows in streaming and online gamingScreenshot_20220512-182130_Chrome.jpg
Harsheet K
Any solution yet? I am facing same problem. I reset my network setting yesterday and all was good. Today the speed slowed down again. My 3 years older device is getting more speed than 2022 flagship S22+ 🤦‍♂️
Kamper
still no solution. the last update did not help. I am very disappointed with such a phone 💰...
Even on youtube AutoQuality set to 240p - on WiFi and LTE+
LOL, samsung flagship phone💩. I have no words 🙊 to describe performance of this phone after 24H since restart.
Kamper
I hope I am not alone and somebody will interest this thing. It's not normal to sell something like this S22 and pretend that there is no problem. It totally hungs up after 3 days of use! All the time. No matter what you do it lost performance. Factory reset doesn't help. Same thing after few days. Waste of money for S22. Not worth even 1/4 of this money.  Every other cheapest phone works better.
