Overheating and Battery drain
(Topic created on: 05-09-2022 04:55 PM)
idlE
Is there any S22 Ultra that goes in overheating and the battery drain so fast ?? And whyyyyy????
Thank you all
8 REPLIES 8
wheiiiiiiiiii
Have you tried galaxy labs?
idlE
Im gonna download it now. But i think ita not gonna work !!!
keith30
Legend
Nope, iv'e had S22ultra since march and never had overheating issues or ecesss battery drain. A lot could be down to the apps your using, Facebook is one of the worse apps that drain your battery.
idlE
I dont use Facebook, i dont know what it is and why the battery drain so fast.
willjoe
Turn On Auto-Brightness Feature:
There are times when you are in the low light setting where you do not need high brightness but your phone does not change its settings accordingly. This is also the main reason why your Samsung S22 Ultra battery might be draining faster
Regards,
Will
idlE
It is ON. ☹️😔
jimmyk87
Voyager
Download good guardians along with the battery tracker and thermal guardian, you'll be able to see whats the cause of the heating and thr drain
idlE
I already have, thank you 😊
