22-03-2022
07:16 AM
- last edited
22-03-2022
09:09 AM
by
AntS
Hello guys.
I want to ask if a 15W charger will work fine on a Samsung S22 Ultra.
For me it's not a problem if It works but charges in 3 hrs to 100%
Thanks in advance for any help
22-03-2022 08:24 AM
22-03-2022 09:50 AM
31-03-2022 08:09 AM
It will work fine. I have disabled fast charge and super fast charge from my phone. It fully charges dead to 100% in about 2-ish hours with fast charging disabled and super fast charging disabled. Also a slower charge is less taxing on your battery, it wears the battery less, also it stresses the battery less, produces less heat during charrfing, and something i noted, the slowest charge with the slowest COMPATIBLE/Slowest SUPPORTED gives you best battery life compared to superfast charging, in very similar device usage. I am considering goid down to 10 watts samsung charger or less if possible, for the reasons i just mentioned.
