31-12-2021 02:52 PM in
My S20 is having a problem with my Headset original AKG, the phone can't recognize the headset, and the notification USB connected/disconnected is always in the notification bar within a loop. I checked the AKG headset with another phone and they are working, also my phone can charge without any issue, also I cleaned up the USB type c port in the phone all is good.
any Ideas?
08-05-2023 09:52 PM in
29-06-2023 04:36 PM in
Same here. Still the same problem with S23 ultra and Samasung wired headphone
06-07-2023 09:00 PM in
The problem that nobody seems to want to mention is that the actual physical port in the phone might be damaged. I find a lot of free play in my plug socket and I am not sure how those tiny contacts are not supposed to short out when I wiggle the plug.
13-07-2023 05:48 AM in
all abit different depend android version on my Note 10+ lastest version Setting > Google > Setting for google apps > Search, Assistant and Voice > Voice > Allow wired headset requests with device locked [ On ]
03-08-2023 11:20 AM in
I have the same issue. S10 with akg headphones usb type-c.
I have tried all @AndrewL suggestions (thank you) and none of them seems to work.
Still waiting for a solution.
18-08-2023 01:47 PM in
Also here to report the same problem on my s10 with AKG headphones. Weird because they've been working fine so far.
07-10-2023 03:41 PM in
Can relate. I used a KZ ZSN PRO in my A02 last year but it broke, I got another one six months after, the same model, but it doesn't work as it should, I got some software problem that disconnects the phone just by touching the plug. It works fine in my computer, in my friend's S20 and I also have two other wired headphones (one USB C and one P2), both working fine in my computer and the smartphone, but when it comes to the KZ it simply doesn't work. What upsets me is that one is the best headphone I've ever used, and Samsung is giving me trouble to use it properly. I don't care anymore, anyway I'll replace it to something with less bloatware, just wanted to note down one of the several issues this company ignores.
21-10-2023 10:41 AM in
Solved! Menu - developer options - media - disable USB audio routing - turn off
