S20 having problem USB connected / disconnected after connecting the Headset
(Topic created on: 31-12-2021 02:52 PM)
AyoubOuarti
My S20 is having a problem with my Headset original AKG, the phone can't recognize the headset, and the notification  USB connected/disconnected is always in the notification bar within a loop. I checked the AKG headset with another phone and they are working, also my phone can charge without any issue, also I cleaned up the USB type c port in the phone all is good.
any Ideas?
15 REPLIES 15
AndrewL
@AyoubOuarti: Can you try pressing and holding on the Samsung Members app icon > Diagnostics > USB connection, and follow the on screen instructions to see if this flags any issues? Also, head to Settings > Apps > Tap the 3 lines with the downward facing arrow to the right of Your Apps > Show System Apps > OK > USBSettings > Force Stop > Storage > Clear Cache > Clear Data, then restart the device. Let me know if this helps.
AyoubOuarti
Yes I already did that, I even deleted the USB update and install it again nothing happens the same issue, I did some researches but it seems that there is the same issue for a lot people but there is no fix for that yet
HKdaBeast
Hello, I'm facing the exact same problem. Have u found a fix for that yet?
Konstigt
Also have this problem. My kids as well on their S10s. Only "fix" is to reboot.. and plug in USB cables 😖
AyoubOuarti
No One is trying to fix this issue, really annoying to have a smartphone that is struggling to recognize it's own headphone,
l96
I'm still having this problem on my S20 as well
Hossain ahmed
Hossain ahmed
If i change the charging port will it be Okey?
AyoubOuarti
Unfortunately not, the issue is still persists, the solution is a wireless Headset
