Wireless charging/Fingerprint issues
(Topic created on: 01-11-2020 05:59 PM)
Dannyboy2018
Pathfinder
Does anyone have a problem with Note10+5G when wireless charging. Both me and my partner has the same device buy when charging (Not all of the time) yoi can hear a virbrating noise as if the Inscreen Fingerprint is trying to activate. We both have the official Clear case too.
Anyone know how we can stop this from happening?
4 REPLIES 4
AsadM
Hi @Dannyboy2018.
Hope you're doing well. As process of elimination, have you tried removing the case from the phone to see if this still happens?
Dannyboy2018
Pathfinder
Hi.
thank you for the reply.
i have never tried but that defeats the object of having a case. There has to be a software issue. Me & my parter has had the phone and case for over a year and this issue only seemed to occur the past month or so.
Both our devices are up to date
MadalinK
Hotshot
Hi @Dannyboy2018 If the sound is like a chirping noise, I can also hear it when charging wirelessly. I am not sure if it's coming from the charger itself or the phone, but I can hear it with my Note20 Ultra too, which makes me think it is the charger.
I have attached a pic of the wireless charger I'm using
Current phone : Samsung Galaxy Note 10+ 5G 512GB
Dannyboy2018
Pathfinder
Hi.
That is the charger i use but that is just the fan making a noise. my partner has the Fast Charger that came out with the S7 and does the same. it's the noise the phone makes when unlocking with Finger print. a constant vibrating noise.
