04-05-2023 01:12 PM
I have NOTE 20 Ultra 5g. This update 5.1 has caused my phone to not charge properly..
it was perfect before the update... no other issues.
Had Samsung service centre tell me to change charging port, but it doesn't charge properly even on wireless charging so it is clearly a software issue.
This is not an old phone and not cheap either. Samsung need to provide a solution... using Samsungs now for about 15 years, and my employees.... this will be last if not resolved.
04-05-2023 04:03 PM
05-05-2023 05:25 AM
Did the Samsung Service Centre have hands on with the phone or advise about the charging port over the phone @Andrew Mellon ?
Do try > Clear Cache Files from the phone's System Partition Section > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too.
You can also run the phone's diagnostic tool in the Battery and Device Care Section.
A Samsung Service Centre can assess your phone if they have hands on.
If I can be of any further help then please don't hesitate. Take care. 😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
05-05-2023 02:44 PM
05-05-2023 02:51 PM
Hi, @EcoBubbleUser944. As the issue is persisting for you, I think it would be worth looking at other solutions. If you're using a genuine Samsung power adapter and cable, I recommend submitting an Error report as soon as you can. This will allow our developers to take a closer look at this for you.
To submit an Error report, please launch the Samsung Members app > Tap Support > Scroll down and tap Error reports > Choose a category of Error report to submit > Complete the required details and then send the report by tapping the send icon.
Please let me know when you get your Note20 Ultra charging as expected again.
08-05-2024 11:24 PM
Ok so as of now I believe I have figured out the cause of the issue. Yes it's a bug in the phone software. However upon switching from usb-c to usb-c cord to usb-a to usb-c has the charging working on both sides of the usb-c connector. Ik it limits the charging speed of the phone but as of now this has been the only solution I have found until samsung releases an update to fix this. Also I use Anker brand cords as they seem to be the least affected by this issue. 6ft usb-a to usb-c cord btw. On Amazon for like $9 for 2. Every usb-c to usb-c cord I have tried and I've tried 8 brands thus far have either failed on both sides or only works as slow charging on 1 side only.
23-10-2024 02:53 AM
23-10-2024 02:54 AM
