Samsung A32 5G charging problem
(Topic created on: 22-06-2024 09:56 PM)
Mete_akturem
My phone doesn't charge with the adapter, but it charges when I connect it to my computer using the same charging cable. I tested the adapter with other phones and it charges them. What could be the issue? How can I fix this?
1 REPLY 1
BandOfBrothers
Samsung Members Star ★★
Do double check the charging port with a torch 🔦 @Mete_akturem
And try Settings > Apps > Tap the 3 lines with the downward facing arrow, to the right of 'Your apps' > Show system apps (toggle this on) > OK > Scroll down, and tap on 'USBSettings' > Storage > Clear cache > Clear data, then restart your device.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
