Exynos S10+ Battery drain on Beta
(Topic created on: 31-10-2019 06:10 AM)
Arshaa
Navigator
My exynos s10+ is DRAINING excessively with the new beta software. While I was sleeping, the phone has lost nearly 23% of its power where the screen is on for just 20 minutes post a full charge. The power management for the exynos was already very bad with the Android Pie software for the exynos variants. (unfortunately I am unable to attach the screenshot with this post)
The general expectation is that with a newer version of OS the battery should always get better no matter what. I believe that should be the same with my phone as well.
I wish this issue gets fixed somehow. I have already submitted a report as well.
@TomaszT just tagging u to bring the issue to your notice.
Tags (2)
32 REPLIES 32
Arshaa
Navigator
Thanks buddy. But I already have it turned on and I also have a lot of other optimisations turned on as well. For instance the power mode is also on optimised.
TomaszT
Beta Moderator
Beta Moderator
Hey @Arshaa
Thanks for bringing it up to my attention!
From what I was told by the development team, there have been some battery optimization tweaks implemented in Beta binary.
Also, they have said that after a software update, it might take 3-4 days for the battery to stabilize.
But they will definitely look into that :winking-face:
Arshaa
Navigator
Hi @TomaszT
That definitely shouldn't mean that post every update I will have power only to last for a meager of 6 to 8 hours. This definitely doesn't seem like something to wait and settle for.
Anyhow, looking forward to the next beta update expecting better performance.
Thanks.
Fortunately I am able to add the screenshot from before now.
deeyup
I have massive battery usage too.
Zero screen on time over night,
Lost nearly 40% in 8 hours.
Granted I did only install the beta 24 hours ago, but if this keeps up, the beta will have to go.
S10e exynos.
Edit, I will try a reset and see if that helps and report back.
Also, I am unable to add photos to this page.
When I click the camera icon, I just get a grey page displaying a broken link icon, and "tap for upload options"
Tapping does nothing.
Edit 2
A cache partition wipe has fixed battery problemScreenshot_20191103-081208_Device care.jpg
Gav4b
Voyager
Im getting great battery life on my S10  far better then I was getting on pie iv been getting 4hours 19mins OST with still 50% left and it seems to still be getting better by the day I left my phone off charge over night to see what the battery drain was like only 2% Screenshot_20191103-182159_Device care.jpg
Jephy
@TomaszT wrote:
Hey @Arshaa
Mines been draining since the last beta, application com.sec.epdg keeps closing. Didn't know until I turned on background errors. Causes momentary lag also when it quits.
ryamoo
Helping Hand
@Gav4b Is that a standard S10, not an S10e or an S10+?
What processor is it - exynos or snapdragon?
I'm lucky if I get 5 hours total OST, so your 4 hours at 50% seems like a distant dream to me.
Gav4b
Voyager
It's just the S10 g973f UK model
ryamoo
Helping Hand
@Gav4b  Yeah, that's the one I have.
What network are you on? Today's usage is looking like 4 hours 40 minutes screen on time.
