S23U OneUi 7, Battery issue
(Topic created on: 14-05-2025 12:15 PM)
Dark0100
When the beta for oneui 7 was normal battery, how come the final release can cause such a big drain issue? My phone has dropped by 40% in the past 3 hours and the most demanding app I used was scrolling Instagram for 1 hour which it says took 10% of my battery. Putting that aside, the other 20-30% gone on standby feels ridiculous?
I have done wiping cache partition etc, so will I just have to wait for an update?
Stuartio
Have you tried installing good guardians? It is brilliant at optimising your system. I had battery drain on my s23 ultra after the update and good guardians app booster and memory guardian sorted it out.. Also turn your screen brightness down when you can as it contributes to battery drain.
2 REPLIES 2
Stuartio
Dark0100
I have tried, but what I am trying to say is we shouldn't have to deal with this when it was completely fine before.
