Battery issue
(Topic created on: 13-03-2025 10:09 PM)
CKFL
S23 ultra here. And since the beta the battery is bad, going fast quickly. UI 7 is great don't get he wrong, and I don't mind the battery draining, but is that normal for you guys?
TechZilla
Samsung Members Star ★★
It is a beta software, this means it will have bugs within it so testers like yourself can report back to Samsung so they can fix it in the next update. Also it's a major update so your phone will need time to adjust the battery by learning your usage patterns.
TechZilla - Samsung Members Star
7 REPLIES 7
TechZilla
Barida
Navigator
I'm currently using the one UI 7, the battery even improved
khxnnn
How can I apply for beta? Also on s23 (ultra)
Galaxy_Note9
My Samsung Galaxy S23 Ultra, running One UI 7, exhibits slower-than-expected battery drain due to the implemented battery limit, a measure to mitigate potential expansion or rapid depletion.
AnnaMaz
Beta Moderator
Beta Moderator
Hello @CKFL,
Thanks for reporting! Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause
Have a good day!
Gedjones
Voyager
My S23u seems to have better battery life.
Is it possible that the battery seems to drain quicker as you are using it more than usual due to what I call new toy syndrome.
1george23
Notice that also, initially after installation but last night when I restated my phone, that's when I've notice the the improvement.
