Battery drain
(Topic created on: 3 weeks ago)
dm117
The battery on my s23ultra is draining a lot faster after installing one UI8 beta
3 REPLIES 3
zkkk
My s23 base battery is lasting years after the update
AnnaMaz
Beta Moderator
Beta Moderator
Hello @dm117,
Thanks for reporting! Please send an error report through Samsung Members app so that the developers can take a look at what may be the cause. You can also try to perform wipe cache partition and see if that helps ‌‌‌‌🤞
Have a good day! ☀️
redsunset2022
Helping Hand
Mine is draining more quickly with OneUI8 beta. Have reported and sent error logs. I also wiped the cache through the boot loader (something I do after installing every patch update). Strangely, I had issues with my email synch stopping after I did this. Maybe unrelated but I reported this too.
