Battery drain
(Topic created on: 17-03-2025 06:23 PM)
veitchie
After installing the ui7 beta software ware the battery is draining faster than normal is this an issue anyone else is finding?
8 REPLIES 8
Gedjones
Voyager
I have not found any difference.
Could it be that you are using it a bit more than usual. New toy syndrome?
If not report it on the feedback section as you log in to members.
vichanu
It's normal, coming days it learn the usage pattern. Also do cache partition.
yamaxt660x
Battery is draining quicker than usual.
AnnaMaz
Beta Moderator
Beta Moderator
Hello @veitchie,
Thanks for reporting! Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause
Have a good day!
MyNamesKrisG
Voyager
Yep. My phone has lost 20% in the last 7 hours, while I slept. That would normally be closer to 5%
1george23
Experiencing the same, with the previous UI i still get around 50 to 60% after a 12hr shift, this morning came home with close to 40%. Still good though.
1george23
How many days have you had the 7?
veitchie
Over a week now still the same
