Go to solution Solved
Strange issues with screen Resolution and Monitor Refresh rates on G9 49" LC49G5T
(Topic created on: 04-03-2025 09:15 AM)
ZebedeeBoss
Ever since downloading and installing Nvidia driver 572.60 (Game or Studio)
My Samsung G9  LC49G5T has some strange issues.
When running 50/50 picture in picture 2560x1440 - you can only select 120Hz (as per spec)
Now on the monitor designated as "Main" in windows I can select 240Hz.  How?
Also using DSR2.25 settings you can normally run 2 x 4k screens
Now the "Main" screen says my native resolution in 50/50 Picture by Picture mode is 3840x1080?? How
Has anyone else experienced this?
I need some help please from the Clever Boyz and Gurlz please.  Thanks in advance Zeb...
2 Solutions
SocietyGirl
Hotshot
Not an expert on this, but maybe in the meantime, you could rollback the driver?
Thoughts are my own.
andytruman
Hey Zeb, I noticed similar weirdness after updating to 572.60 too. My G9 started reporting odd refresh rates and resolutions in PBP mode. I think the driver is messing with how Windows handles display scaling and EDID info. Rolling back to the previous driver fixed it for me. Might be worth a shot until Nvidia sorts it out.
4 REPLIES 4
SocietyGirl
Hotshot
ZebedeeBoss
Hi, thanks for the reply, I was hoping not to have to do that as the 570 series of drivers allow access to DLSS 4. I guess that will be the ultimate option.
Thank You...
ps I guess I should have stated (in case it makes a difference) I am running an AMD 7800x3d paired with an RTX 4070
andytruman
ZebedeeBoss
Hi, thanks for the reply, I rolled back to 566.36 until they sorted it out.  I meant to mark the topic as resolved after @SocietyGirl replied to roll back.
Appreciate you taking the time to reply.
