Smart Monitor M7 - WiFi to LAN
(Topic created on: 29-04-2022 12:22 PM)
MYU_QPR
I understand the M7 is a wireless TV/Monitor. However, every so often the Internet speed drops so much, and the only way to fix it is by disconnecting and putting the password back in.
I want to hardwire the monitor as I have 3x USB ports and 1 USB-C port.
I have spent just under £200 on different hubs and adaptors on both ports, all of them failed.
I have tried the adaptors on other devices and they are not faulty.
Below are some of the items I tried to use:
USB 2.0 to RJ45 Fast Ethernet Adaptor.
USB-C to RJ45 Fast Ethernet Adaptor.
USB-C HUB 10 IN 1 - Tried it plugged into the mains and without.
USB-C HUB 5IN 1 - Multiport Adaptor - Tried it in mains and without.
I have an adaptor and cable arriving from Amazon today, I don't think they will work as they are USB 2.0.
I also tried one from Costco and that failed too, I got a full refund on that though.
I have tried 3 different RJ45 cables, 3 different USB cables and one is very expensive.
How can I hardwire my M7 to Lan, and bypass wifi?
Cheers if anyone can help.
1 REPLY 1
MYU_QPR
