Samsung G70A DisplayPort audio issue - random white noise audio from speakers.
(Topic created on: 25-02-2023 11:57 AM)
mokurai82
My Samsung G70A monitor connected speakers make loud noises in random intervals when on DisplayPort.
I tried different settings, cables and devices and the issue persists.
This does not happen on the same devices when connected through HDMI.
I am currently on firmware 1008.1 an I am looking for newer or older firmware files to see if those can fix this issue.
The full model number is LS28AG700NUXEN and the current software version is M-A7000GGZA - 1008.1
If anyone could hook me up with other firmware files I would be really grateful, as I would like to avoid sending the monitor back.
EDIT: This issue is not there on Firmware M-A7000GGZA-1004.0 that I have downgraded to.
If anyone has other firmware versions I would still be grateful as they may provide better picture quality.
3 REPLIES 3
mokurai82
The issue reappeared even on firmware 1004.0. Please fix it Samsung.
Mahboishk
Think I have the same issue on a LS28AG700NNXZA (appears to be the exact same monitor model, despite different ID). When using my desktop PC connected via DisplayPort, connected speakers randomly play a burst of static / white noise at the highest possible volume set by the speakers. Seems to be completely random, even occurring while the PC is outputting audio via other devices.
The issue is not present on my MacBook Air hooked up with a USB-C to DisplayPort cable, nor my PS5 or Switch hooked up via HDMI.
mokurai82
I still have this problem even on firmware 1009.0
I still need to disable my GPU Audio and use a different sound card.
I think this will be my last Samsung monitor.
