Odyssey G7 will not turn on, no LED either
(Topic created on: 24-07-2023 04:41 PM)
G7wontTurnOn
This appears to be a common issue, is there a common fix?
Leaving the monitor off and disconnecting and swapping plugs seems to make no difference. Swapping source and swapping cables also made no difference and seemed pointless as the screen wont even turn on for me to change the source anyway. It seems completed dead.
8 REPLIES 8
Members_TjvJ5wE
the same has happened to me, i've bought a new power brick to no avail
the board is getting power but it's not lighting up at the switch or anything
Markuski
Hei folks, I've just bought a G7 and im not getting any power at all. My pc and 2nd screen are connected to the same outlet and are working fine. Did you folks found a solution if please let me know.!!!
Chewy1394
I had the same problem with 2 of these monitors now. Had to send them both back. First one was replaced, and the one now is going to be checked by a technician. So unfortunate
Joel27martinez
I've faced the same issue, yesterday I was gaming with this monitor without any issues. Woke up to not powering on and no LED blue light indicator. I ordered the following Power Brick https://www.amazon.com/Samsung-120W-Replacement-Adapter-All/dp/B006UO0P6O/ref=sr_1_16?crid=1NEOB4DRK... Will see if it works.
alexangel61
Same ***** thing happened to me. on DAY ONE. As soon as I plugged it in it did this to me. RIDICULOUS. DAY FING ONE. Cant plug it in at all
Halvor
my G7 just died as well. no light in power button. had trouble beforehand of it turning off regulary where i had to disconnect power and reconnect to get it to start. felt for overheating etc but nothing seemed out of the ordinary. then at last it didnt want to turn on at all. completely dead.
halfgrid
Absolutely the same happened to me today. It’s been an ongoing issue for like a month, unplugging and plugging in. and today morning it completely died.. What was a resolution for you
Markuski
Hei, my fix was simple, the  issue was with the power cable. It was malfunctioning as it would sometimes work or not. So i just bought a new one which was like a 100$.
