03-01-2023 04:13 PM
Hello everyone,
I've spent over two hours chatting to Samsung Technical support who are no closer to resolving a solution - all that I need to do is to get the power adaptor further away from the soundbar.
They can't
1 - confirm if it's an ordinary two core cable that I can simply cut and extend
2 - tell me what pin sizes are used so that I can get an extension made up
3 - contact Head Office and ask for specification details
Needless to say it's been like banging my head against a brick wall
Solved! Go to Solution.
01-03-2023 03:18 PM - last edited 01-03-2023 03:20 PM
I figured out a solution! I spent way too long on this problem.
The HW-s800b and HW-s801b soundbars require a 3.0x1.1m DC connector pushing at least 19v/30w power. The power adapter that came with my soundbar (which I assume is the same for all) was a 3.0x1.1mm DC 19v/60w adapter that only went about 5ft from the TV before having a big brick attached to it, which was frustrating to hide.
I could not find a 10ft+ 3.0x1.1mm DC power adapter at all, so I opted to combine some parts to make an equivalent over USB-C.
I purchased the following 4 items, which powered the sound bar and provided some choice in length, thinness and avoided Samsung Support entirely:
I hope that helps! It works just like the original power supply, fits in a cable wall sleeve nicely, and shouldn't be too budget-breaking (although the total solution cost about $60, not exactly great). I ran the cable through a wall sleeve under the Frame soundbar and then under a rug to get behind the couch, out of sight.
Enjoy!
22-02-2025 10:07 AM
My solution was really simple in the end.
I inset the power brick into the wall and extended the live 240 feed. Really easy, works perfectly, I’d just
been overthinking the solution.
Enjoy!
19-03-2023 11:29 PM
You are awesome! Been trying to solve this for weeks. Thank you!!!
12-06-2023 12:27 PM
(if I could find one) would a 3.0x1.1mm male to female cable work here with the supplied psu?
12-06-2023 05:06 PM
I just want to share my solution. I had the exact same problem. The DC cord from the adapter being too short.
I tried all solutions mentioned here, converters, USB-C extension cords etc. from AliExpress. Couldn't find a working solution, so after countles hours i tried the most simple solution. Cut and extend the existing wire.
Cut the DC wire and use a regular wire you would use for any electronic to extend. It works just fine. Also use some Heat Shrink Tubing to get it done correctly.
03-02-2024 05:32 PM - last edited 03-02-2024 05:32 PM
Thank you for saving my installation 🙏
28-02-2024 09:43 PM
Hi there,
Any chance you can give me more information on what cable would be suitable to buy for following your instruction?
Thanks! 🙏
04-03-2024 08:01 PM
Hi,
I used an ordinary 2-conductor extension cord like you would use for a regular lamp.
Like this: https://www.amazon.com/Conductors-Resistant-Electrical-Extension-Lighting/dp/B08FMMZHQ6?th=1
Where I connected the wires, I also used heat shrink tubing to get it properly assembled.
Like this: https://www.amazon.com/Shrink-Tubing-Industrial-Heat-Shrink-Wires/dp/B0BG6V4HV4
Works like a charm and no need to use all kinds of converters
07-04-2024 06:48 AM
Just get longer cable the same as the one you have from Amazon or eBay,. I used the European wire to extend my TV cable, and have had no issues. I doubt you could lengthen the power to soundbar wire though
30-09-2024 02:22 AM
You would think there would be a 3.0 x 1.1 mm barrel extension somewhere.
Has anyone found one yet??
