HW-S66T/S67T Soundbar bluetooth audio delay
(Topic created on: 08-09-2021 06:13 PM)
ksvends
There is at least half a second delay using this soundbar connected via Bluetooth.
How do I fix this?
All my googling tells me to press audio controls/sound control on remote. No such button. Or adjusting TV settings, when its not a  TV that I'm connecting, that wont help either.
3 REPLIES 3
AndrewL
@ksvends: The Sound Control button has a cog symbol on it, and is on the right side of the remote, above the Woofer button. Press this until 'Sync' is selected, then use the Up/Down buttons to set the audio delay between 0-300 milliseconds.
ksvends
Hi,
When I press this I get
Travel - Bass  - Side Level
Then back to Travel again.
no Sync.
Vonken
I have the same issue. No "Sync" in the settings. Has there been any fix?
