HW-Q90R sound control: can't adjust treble bass &C
(Topic created on: 18-04-2020 10:48 AM)
19fede73
Hi. It seems that if I press the soundcontrol on the remote and I change the treble number from 0 to 6 it doesn't memorize that number. And if I check another time the treble is always in 0 position setted. So it doesn't memorize it.
Same thing when I try to change the sound of the frequency band.
Note: the firmware is update to 1008.0 version.
Note 2: when I try to up the treble the message is "Treble SW + 6"
Note 3: I'm in TV ARC mode with a Samsung TV
Any solution?
2 REPLIES 2
19fede73
Any solution?
19fede73
Ok I solved. You have to change the values only with the "circular" key of the remote control.  When you push the woofer button, the soundbar reset the treble &C.
