HW-Q700A No Sound over Spotify Connect Wifi - FIXED
(Topic created on: 25-09-2021 02:17 PM)
Bright1
Update:
Fixed the problem. Turned everything off, restarted all devices swapped the Wi-Fi from using my extender to connecting directly to the router, deleted and re-added the soundbar and then it worked. Not sure what part of this made the difference but it fixed. I am not sure how to delete with post now but thank you if you did stop to read it.
Hello everyone,
I am wondering if anyone can help shed any light on this issue?
My HW-Q700A soundbar is connected on my home Wi-Fi with no problem, the smart things app finds it, Spotify lists it as a device and the soundbar display responds when it turns the volume up and down through both the apps. However, there is no sound from the bar at all in this mode.
Bluetooth audio connects with no issue so the bar definitely works, just not over Spotify and Wi-Fi.
Any suggestions would be welcome as it all appears to connect but with no sound.
Many thanks
Tags (1)
48 REPLIES 48
Franci2
Pathfinder
Short-term solution Disconnect the power supply oder reset.
Long-therm solution, I hope Samsug or Spotify find make an update.
Franci2
Pathfinder
Yes thats true but it isn't the long-therm solution. We hope that Samsung and Spotify find a solution.
Franci2
Pathfinder
Good Morning all,
I want to give you an update on what happened yesterday on the subject.
1. Yesterday I contacted the Spotify support (chat) and described the problem. They couldn't help me and asked me to email the matter to support (support@spotify.com) now I'm waiting for a response.
2. Yesterday I received the first written response from Samsung support about this:
"Good day,
Thank you very much for your email. I looked at the matter.
We are not yet aware of such a series defect, so I assume that your product has a technical defect.
If this error should also occur with the new product, you are welcome to contact us by e-mail or by phone.
I hope I was able to help you with the answer and I am happy to answer any further questions you may have.
Kind regards from Schwalbach "
My request to you Comunnity members, report the above problem to Samsung Support (hotline@email.support.samsung.com or hotline@samsung.de)
The problem will only be taken up and acted upon if enough reports are received by Samsung.
Currently the problem does not seem to be known to Samsung or I am apparently the only one who reported the problem according to Samsung and therefore they assume that it is not a serial problem.
When I suggested that you have a look at the community entries, so far only responded with an answer, please write us an email.
Thank you in advance for your support, together we can make a difference!
Oscarmeier
Habe das gleiche Problem mit der HW-Q800A. Werde das heute dem Support melden, solange kommt da eine WLAN Steckdose dran zum Reseten. Sehr schade bei dem Preis.. hätte besseres erwartet.
Products mentioned in this post
Franci2
Pathfinder
Hallo Oscarmeier,
vielen Dank für dein Meldung. Das mit der WLAN Steckdose ist zumindest eine gute abhilfe um die Anlage vom Strom zu trennen. Ich hoffe jedoch das es nicht dabei bleibt, den das wäre für ein Produkt welches mit der Funktion "Spotify Connect" wirbt fatal.
Der "Spotify Support" hat mich gebeten eine Videoaufzeichnung vom Problem zu erstellen und diese denen zu zuschicken. Das habe ich gestern gemacht, ich bin gespannt auf die Rückmeldung.
@Oscarmeierhalt uns bitte auf dem laufenden sobald du von Samsung eine Rückmeldung erhälst. Im deutschen Samsung Community Thread (oben von mir verlinkt) werde ich die aktuellen Infos dazu teilen.
StevieU2
Hi everyone,
Having the same issue here with the HWq900a. But power off doesnt fix the problem
So I am without spotify connect with a very expensive product. Samsung please fix this
TrainOfMyLife
Same experience with my Q700a: No sound through Spotify Connect since yesterday, even though everything seems to run smoothly and all other functions are intact.
Very annoyed, since spotify connect was one of the main arguments for that soundbar. Get it fixed Samsung!
Franci2
Pathfinder
Hello@StevieU2 ,
thank you for your message. I/we ask for your support, please write an email to Samsung Support directly. Look here:
Here you can find the current status of the Spotify problem and feedback from Samsung Support:
https://eu.community.samsung.com/t5/audio-video/problem-soundbar-hw-q950a-gt-tonausfall-verzerrung-i...
Franci2
Pathfinder
Hello @TrainOfMyLife ,
ClemensRausch99
Pathfinder
@Bright1
Experiencing the same with my q950a. Did your claimed fix resolve the issue permanently for you?
