Cannot alter volume on soundbar using Smart Remote
(Topic created on: 08-02-2022 07:39 PM)
I have this problem too
rmulls
I have a Q60A 43" TV and a Bush soundbar with no HDMI connector. I use the optical connector to connect to the TV. I was wondering if there was a way to change the volume directly from the TV's remote (Smart or Normal). At the moment I can only do it via the soundbar's own remote. When I press the volume buttons on the smart remote the word "Optical" appears on the left of the screen but nothing else. I have already altered the TV settings so that "Optical" is selected. I am beginning to think that this will only be possible with a HDMI conenctor (which my soundbar does not have!)
1 REPLY 1
xSteveuk
Mastermind
Hi,
This page may be helpful to you
Control your soundbar using your Samsung TV remote
https://www.samsung.com/us/support/answer/ANS00049279/
