12-01-2024 01:49 PM
23-03-2024 02:47 PM
I have 2 tags. They both make the battey beep randomly while on my key ring with a key fob. Replaced batteries and all other suggestions. When I remove them from the keys they no longer beep randomly. Hope this helps.
10-04-2024 09:16 PM
I solved the same problem changing the battery. Original batteries are not fully charged.
10-04-2024 09:16 PM
Same problem solved with a new battery.
10-04-2024 09:17 PM
30-04-2024 11:29 AM
Same issue here: Is there any fix? is it a faulty hardware design?
30-04-2024 11:35 AM
2 weeks ago
I previously had the original smart tag and had no issues. But I recently purchased the smart tag 2 a three pack and two out of the three are doing random beeping constantly. Every time there's movement, I've changed the battery and I've cleaned it but the issue still occurs.
2 weeks ago
Friday
